2005 4.7l freefloating shifter.
Old Jun 20, 2018 | 11:01 AM
kodiking2's Avatar
kodiking2
Default 2005 4.7l freefloating shifter.
Basically it’s stuck in 4L right now and shifter is free floating. Wondering if someone has a quick little video showing where the switch is on the transfer case for me. Just want to switch into 2H so it’s drivable now then I can tear it apart see if it’s a quick and cheap bushing fix or full linkage.
Old Jun 21, 2018 | 07:55 AM
Crawl under there, and see if the linkage did indeed fall off. You might be able to stick it back in place long enough to get back into 2 hi.......
Old Jun 21, 2018 | 07:59 AM
kodiking2's Avatar
kodiking2
Ended up finding it and manually doing it by hand. Found the rod and bushings for $60 new so going to get that done tonight hopefully. Glad it’s a cheap easy fix *knock on wood*
