04 dodge ram hptuners speed calibration
Old Jun 27, 2018 | 07:37 PM
justin0943's Avatar
justin0943
Default 04 dodge ram hptuners speed calibration
okay so I put new pcm on the truck and finally took to my buddy so he can adjust some stuff with his hptuners got everything done except the speed calibration, my truck is 5mph off and so when hitting 60mph its only going 55mph an the cruise control doesn't work after 65mph, below that it works perfect.the hptuners doesn't give the option to adjust anything with the speedo, so what to do?
Old Jun 27, 2018 | 10:56 PM
primem's Avatar
primem
if the speedo is off from a tire size change...you should be able to go into a module and change the tire size. On my 07 its in the tipm. Not sure which module performs this function on a 04 but its there.
the tire size change for mine was 17's to 20's. Not only did it skew the speedo but it caused late upshifts...putting in the correct size fixed both issues. All that is need to change mine was a full function scan tool that could access the tipm.
Old Jun 28, 2018 | 07:59 AM
justin0943's Avatar
justin0943
yeah their no option for any of that he showed me for a chevy he was tuning that had all kinds like gear ratio, tires and all but on mine their nothing
Old Jun 28, 2018 | 11:33 AM
HemiLonestar's Avatar
HemiLonestar
On that year it's tcm if I remember right, look for something called "pinion factor". DRBIII it's an option.
Old Jun 28, 2018 | 03:07 PM
justin0943's Avatar
justin0943
no mine is the all in one deal.one with the 4 plugs on it
Old Jun 29, 2018 | 09:20 AM
HemiLonestar
Then it's the TCM side of the PCM, regardless it's still called "pinion factor". Should be under transmission options. If not then HP tuners sucks lol.
Old Jun 29, 2018 | 04:45 PM
justin0943's Avatar
justin0943
okay I'll ask him about it then get back with you
