Ram 1500 Having Issues
Old Jul 2, 2018 | 02:27 PM
KTBlake's Avatar
KTBlake
Default Ram 1500 Having Issues
Hi I am currently a new member to the forum and was seeking some advice or help. I own an 04 Ram 1500 Hemi 4x4 with around 124k miles. I was driving home normally one day from work and truck started driving odd; dying at stoplights and stop signs, bogging down while accelerating from a stop or with a load, and the sound of a misfire. Popped a code for the IAT sensor so I cleaned it off and code went away and was replaced with an O2 sensor code. I proceed to change that also until yet another code popped for Cylinder 5 misfire. I went ahead and checked the sparkplug, which had fuel on it so I changed the fuel injector and all 18 sparkplugs cause they were worn also, runs a little better but still nothing changed. The misfire sound is on the opposite side of the engine where the flooded sparkplug was, so I thought it could be a plugged Cat cause back pressure on the valve, cat was clean so another option out. I checked the vacuum lines to look for a hole, took a pressure valve to the fuel rail and looked all good, took oHms readings of all coilpacks and EGR valve. Decided to bite the bullet and take it to a local shop to where they said it had a bad pushrod (on the misfire side) and that that was the only thing they found and that they never seen anything like this. I wanted my truck back to figure it out myself instead of blowing money on a shop that took too long before I need to go back to work. Today I unplugged an upstream O2 sensor and ran the truck to see if it would run worse and didn't change at all. So I changed out that one also. Yet again, truck runs a little better than before but still no solution to the problem. If you have any suggestions please comment where any advice is much appreciated.
Thank you
-KT
Old Jul 2, 2018 | 03:19 PM
Do you actually HAVE a bent pushrod? If you do, need to find out why it bent..... If it's still in there, yes, it is going to cause a miss, you have a valve that won't be opening all the way.
Old Jul 2, 2018 | 03:42 PM
KTBlake's Avatar
KTBlake
Mechanic said it was "bent" but it wasn't actually bent. He changed it out and gave me the old one. Old one had a mushrooned top and while he was in there he checked all the valves with a mirror. Valves were all good
