2005 Cummins front brakes dragging
Old Jul 15, 2018 | 09:03 AM
seokladuckin's Avatar
seokladuckin
Default 2005 Cummins front brakes dragging
2005 cummins 4 wheel drive , 80K miles garage kept , original pads with very little wear .
got home yesterday and both front brakes were HOT ,, I jacked front up and I could turn them but they were tight , rear not affected .
so is the hydo-boost bad?
or master cylinder bad?
or anti lock valve bad?
never had not one problem with this truck ...
at a loss
Old Jul 15, 2018 | 09:20 AM
Pump up the brakes so they are good and tight, try and turn a wheel. If it is really stiff, crack open the bleeder valve. If it is not easy, replace the soft lines.
Old Jul 15, 2018 | 10:06 AM
seokladuckin
it's both sides , really don't think it's the hoses both at one time ,, odds would be very high
Old Jul 15, 2018 | 10:07 AM
seokladuckin
it set overnight and they are not hanging ,, fixing to go drive it and see what happens
Old Jul 15, 2018 | 10:11 AM
It's a process of elimination. While odds are against both lines failing at the same time, it isn't unheard of. Need to check it, to eliminate it as a possibility.
Old Jul 15, 2018 | 01:45 PM
seokladuckin
been driving it this morning cannot get it to do it again ,, got on brakes hard 3-4 times ,
Old Jul 15, 2018 | 01:49 PM
Of course not. Now you are actually looking for the problem, so it is 'hiding'.
