2003 Ram 1500
Old Jul 17, 2018 | 10:42 PM
Jadams505's Avatar
Jadams505
Default 2003 Ram 1500
I just changed the t-stat and refilled with coolant. I have bled the line for quite some time and still getting air. No leaks. How long should it take to get all the air out?
Old Jul 17, 2018 | 10:54 PM
Ramman18's Avatar
Ramman18
Put the cap on and drive it. Air should work out. I've never seen a mechanic do anything more than that and neither have I.
BTW, your truck is considered 3rd gen (2002-09) so you may want to post there for more info for your particular year.
What engine do you have?
Old Jul 17, 2018 | 11:16 PM
Jadams505's Avatar
Jadams505
Thanks Ramman18! Its a 4.7L V8. The only reason I ask is because recently towing my trailer the radcap blew off. I don’t know if it was due to a faulty cap or because the t-stat was stuck open.. I haven’t pulled anything since but ran it and no issues. I have read some threads talking about a head leaking into the cooling system causing pressure. Didn’t know if excessive bubbles would be a sign of that or not..
And I have no clue how this ended up in the 2nd gen thread lol
Thanks you again for your thoughts!
Old Jul 17, 2018 | 11:57 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
And I have no clue how this ended up in the 3rd gen thread lol
You are in the 2nd gen section (94-01) your truck is a 3rd gen (02-08). The bubbles really isn't a way to tell. Any smoke coming from the exhaust? You can have the coolant tested to see if it is a head gasket (really cheap to do). If it's bad enough sometimes you can pull the plugs and see antifreeze on the plug. Or if you have a scope can look into the cylinder
Old Jul 18, 2018 | 12:04 AM
Jadams505's Avatar
Jadams505
So no smoke even when starting... what places can test the coolant?
Thanks for the help!
Old Jul 18, 2018 | 07:38 AM
You can get a kit from your local parts store, and do it yourself. I'll move this to the third gen section for ya.
