03 engine swap
Old Aug 28, 2018 | 10:08 PM
Kevin Steglich's Avatar
Kevin Steglich
Default 03 engine swap
Anyone ever swapped 5.7with5.9 gas on 03 ram 1500 2wd
Old Aug 28, 2018 | 10:24 PM
Major pain. Everything is different, from the mounts, to the electronics. It's been done, but, it ain't easy, and it ain't cheap.
Old Aug 28, 2018 | 10:33 PM
Kevin Steglich
Okay thanks I was trying to save money on replacing the 5.7 those things are 💸💸💸
Old Aug 28, 2018 | 10:37 PM
Kevin Steglich
My 5.7 locked up and those things are expensive
Old Aug 29, 2018 | 07:26 AM
You'll spend even more trying swap in a 5.9.
Old Aug 29, 2018 | 09:22 AM
tnucastehc's Avatar
tnucastehc
Electronics are too different, 5.7 has an electronic TB, 5.9 does, different transmission, cruise control is fully controlled by PCM for the 5.7 (no solenoid), etc etc
Old Aug 29, 2018 | 10:07 AM
Kevin Steglich
Thanks guys I will just stay with 5.7
Old Aug 29, 2018 | 10:34 AM
tnucastehc's Avatar
tnucastehc
Just make sure you stay with the right generation; nothing newer then 2008.
