Overheating
Old Sep 6, 2018 | 09:06 PM
Grayslope1912's Avatar
Grayslope1912
Default Overheating
2004 Ram 5.7 Hemi 200,000 miles. New water pump, radiator, hoses, no leaks, no white smoke, no loss of coolant. Heat gage stays at the 12 o'clock position but will rise to 1 o'clock position at idle when outside air temp reaches 90 degrees . But will drop to normal when driving down road. So - head gasket? Thermostat? Any help would be appreciated..
Old Sep 6, 2018 | 09:11 PM
Fan clutch, or electric cooling fan. Either that, or its perfectly normal behavior for when it is that hot out.
Old Sep 9, 2018 | 08:21 PM
Grayslope1912
Found issue - It was radiator cap! Some crack in sealing gasket. Bought a new one and issue went away.
Old Sep 9, 2018 | 08:29 PM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
Good to hear it was an inexpensive and easy fix.
