Truck randomly shuts off
Old Sep 11, 2018 | 09:18 PM
Trent Racer's Avatar
Trent Racer
Default Truck randomly shuts off
Hello folks my 06 ram 1500 4.7 doesn't do it often but every once in a while just shuts off randomly going down the road i turn the key on and off fires up like nothing happened so I'm confused on this any tips will be appreciated
Old Sep 12, 2018 | 11:21 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Might be throttle position sensor or you are losing fuel or spark. Diagnosing problems like this when I worked at the Dodge garage was very tricky as you get no information when it shuts down. So we would literally just throw parts at it. To me seems like either a sensor is failing or bad coil(s). When does it do this? When the engine is hot? When the weather is hot?
Old Sep 12, 2018 | 11:40 AM
Trent Racer
It generally does it when its hot and after driving for a while i was on the I 66 for 3 hours i picked up speed to 70 mph shut off acted like it lost fuel pressure all together turned the key off and on and started up like it was nothing
Old Sep 12, 2018 | 04:51 PM
TrueDogman's Avatar
TrueDogman
Ignition switch ? Play with it a bit while your driving or engine running ???
Old Sep 15, 2018 | 04:08 PM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
I had this happen to me once after about 2+ hours on the Autobahn. I exited into this little village, and as I was slowing down the truck just shut off. After a few minutes I was able to get it restarted, but haven't had any sort of issues like that since then. The code that popped was for EGR, which I promptly replaced. I've had an intermittent CEL for the EGR, but no further total loss of power problems.
