Question for those who swapped from 3.92 to 4.56 gears
Old Jan 6, 2006 | 06:46 PM
frogslinger's Avatar
frogslinger
Default RE: Question for those who swapped from 3.92 to 4.56 gears
actually for a rear gear change you do not need to recalibrate your speedo in our trucks... the vss runs of the wheel not the transmission like it does on most vehicles, so you only need to recalibrate when you change tire height... You should recalibrate anyway, because it throws off your ABS system, but your speedo is unaffected by rear end gear swaps.
Old Jan 6, 2006 | 10:55 PM
HemiRam_05's Avatar
HemiRam_05
Well I have a 3.92 rear and no limited slip.. can i put a 4.10 or even a 3.92 with limited slip in stock or aftermarket?.. dealer wants $3000 for it..
Old Jan 6, 2006 | 11:33 PM
frogslinger
yes... dodge does not make any gears higher than 3.92 so they will have to be aftermarket. You can put a stock or aftermarket LSD in your housing just fine, just so long as you FM. Mine cost about 800 to do. LSD changes the drivin charecter of the truck... you launch harder, and get better traction on dirt but the truck tends to develop a little more power oversteer.
Old Jan 7, 2006 | 02:53 AM
coryk4's Avatar
coryk4
ive got 3.55 in my truck. how much change would it be to go with 4.56. i know that i would have to get my speedo redone. but are there any other things that would have to be done.
Old Jan 7, 2006 | 03:45 AM
BlueHemi's Avatar
BlueHemi
ORIGINAL: coryk4
I went from 3.55 to 4.10 and it cost around $650. The ring and pinion gears and the complete installation kit cost a little over $300 from a speed shop here in town and the install itself was $300.
After the install I had the dealer flash the pcm with the new "pinion factor" as they call it for $70.
Old Jan 7, 2006 | 05:27 AM
frogslinger
Like I said... reprogramming your speedo is not required... it will read right. All you are doing is resetting your ABS.
