Remove Cylinder head
Old Dec 13, 2018 | 08:58 PM
Grayslope1912's Avatar
Grayslope1912
Default Remove Cylinder head
2004 Ram 1500 5.7 hemi.
Have to pull head on Bank 1. How many issues am I gonna run into.
Old Dec 14, 2018 | 09:59 AM
Depends on your luck. If it's good, you won't run into any. If it's not.... you will run into all of them.
Old Dec 14, 2018 | 01:06 PM
Grayslope1912
Yes I would guess that!
It's a southern truck, so hoping for the best.
Thanks
Old Dec 14, 2018 | 07:32 PM
3rdgens4sell's Avatar
3rdgens4sell
Why do you have to pull the head? No real information in your post other then you believe in luck apparently.
Old Dec 14, 2018 | 09:04 PM
Grayslope1912
Well if I were lucky I wuld not be planning to pull the head. Had issues with the engine so did a compression test. All reults were good, within acceptable limits except for cyl 1 which read 0. Suspect a valve issue at this time. Pulled valve cover and could not see any issues. Next step is to do bring cly 1 to TDC and do a leak test to see where air is coming out - TB, exhaust or oil fill. Hopefully TB or exhaust.
Engine is high mileage but no sludge or gunk under valve cover. Maintaince has been kept up. Truck is an 04 2 door, Larmie short box Black with an SRT hood. Truck has all options on it as it came from Dodge. It looks like a Rumbe Bee & often mistaken for one, but it is not. The only mods are- performance chip, cold air intake & dual exhaust from manifold back with no cats.
Hate to lose it.
