Desperate need of help
Old Jan 19, 2019 | 03:40 PM
campermama's Avatar
campermama
Default Desperate need of help
04 dodge 2500 ctd 5.9l 4x4
How the heck can I get the power steering return hose off the bottom of the reservoir? I need to replace it. There is pretty much no room to work in there. I was able to move the clamp down but now I can't slide the hose off. It will twist, it's not stuck. I just can't grab it to slide it off.
I can't take the reservoir off either, only one screw is accessible.
Any ideas?? Thanks!!
Old Jan 19, 2019 | 03:56 PM
If you are replacing the hose anyway, slice it open with a knife where it goes on the nipple to the reservoir. Should then pull off easily.
Old Jan 19, 2019 | 04:10 PM
campermama's Avatar
campermama
Now there's an idea!!
It's actually leaking where the 3 hoses meet, was hoping to pull the whole thing and fix the connection and put it back, but cutting it my be my only option at this point.
