2005 1500 4.7 stalling
Old Feb 2, 2019 | 09:28 PM
Dieseldaddy1981's Avatar
Dieseldaddy1981
Default 2005 1500 4.7 stalling
My truck finally runs again. New plugs, pcm, crank sensor, cam sensor, and fuel pump. The issue is this. It starts perfect, idles perfect, but after a couple of minutes, it just dies. It will start back up with no problem. It will idle sometimes for one minute, sometimes 10. Drove it, and it had no issues. Also have no issues as long as I give it a little gas. I am not sure what else to check.
Old Feb 3, 2019 | 09:29 AM
Your truck is a third gen, moving this to the correct forum.
Have you cleaned the throttle body?
Old Feb 3, 2019 | 06:02 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Get ONE new ignition coil and replace them one at a time until the dying issue stops. Also make sure you didn't crack a spark plug
Old Feb 3, 2019 | 08:50 PM
Dieseldaddy1981
It pulls a p0336, p0300, and p0315. All point to crank sensor, and that has already been changed. I do have a couple extra coils I will start swapping them around. Got it on the road, and it ran great down hill and level, but going up an incline, she jolts and hesitates, and the rpms are all over the place.
Old Feb 3, 2019 | 10:25 PM
Is there a crankshaft sensor relearn procedure for that???
