Fuel supply issue
Old Feb 5, 2019 | 12:34 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I would be hoping it wasn't the pump.... Those are a drag.
I'm with you on that.
Old Nov 11, 2021 | 05:25 AM
William Hatmaker's Avatar
William Hatmaker
theses guys don’t know. Got two we are working on n replaced the pumps on both. Somewhere on here is a mechanic going into detail on how to chase down the wiring system n it fixed the van/truck. I had saved the text but accidentally deleted it before I got to follow the instructions. Two relays. One kicks on pump when key is on crank. Then other relay takes over when van starts. Something about a big junction box that has grease in it to keep connections from corrosion. Grease gets dry/hard n could be the problem. If u find the q and a on forum on here could u please relay it to me. I haven’t been able to find it again. After three fuel pumps that last a week at most. It’s probably not the fuel pump. But for your sake it would be easier if that’s all it was
