pinion bearing face damaged
Old Feb 14, 2019 | 07:07 PM
nelllake's Avatar
nelllake
Thanks for all the advice. I decided to leave it alone and press the bearing on. I don't have anybody near by to lash a new ring and pinion without putting it on a trailer in the middle of the winter and vice versa. AGAIN THANKS FOR THE ADVICE. YOU ALL ARE VERY PROFFESSINAL AND IT IS DEEPLY APPRICIATED. NELLLAKE
Old Feb 14, 2019 | 07:30 PM
00t444e's Avatar
00t444e
All you need is a dial indicator with a magnetic base to set your backlash, but since you have it all apart you will need to seat your pinion depth and preload as well. You will also need to buy or make a special tool to turn the side adjusters for the carrier, I made my own with a 36 mm nut welded on a 1/2" piece of pipe and a bolt welded in the other end so you can get a socket on it.
