3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Help, front end of 2006 Ram has developed front end vibration at highway speed. Alignment lessened problem but it's coming back. Oddly, vibration disappears in 4WD. Any suggestions to the cause
(likelyhood)
Failing CV axle (3), wheel bearing hub (4), lower ball joint (2), front drive shaft CV/Ujoint (7), front shocks (5), tires wear or balance (1), warped brake rotor (6).
