3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
How to tell a 47re from a 48re OD.And will the guts from a 47 fit a 48 OD ?
This all started when trying to fix park .Pulled the OD out ,and found a broken snap ring so i took it to a trans shop .Trans shop said i might have the wrong park rod .I did some Google and find i may have a 47re OD unit .How to tell ,and will the guts from a 47re fit a 48 re . I need to get park fixed .
Because i know where there is a 48 re case i could get .
All is good though as i found out my OD unit is 48re .
still have to find out why the park does not work .
