Oil sensor switch
Oil sensor switch
My 07’ Ram 1500 has the 4.7 engine. I just bought it a few weeks ago. Has 84,000 miles on it
Truck runs fine , but the oil gauge doesn’t work and the check gauge light is on.
I replaced the sensor with a new one, but the gauge still doesn’t read anything and the check light remains on.
Any suggestions as to what could be wrong?
Possibly bad gauge? Possibly new sensor is bad? Like I said, truck runs fine, but not real comfortable with no oil pressure reading. Thanks
No code at all. I have to get a mechanical gauge to check actual pressure too.
If the pickup is clogged, I assume I will need to drop the pan. How difficult is it on a 2 wheel drive truck?
Thanks for you initial in put. I appreciate it.
