Reduced air flow in all HVAC modes
Old Apr 7, 2019 | 06:24 PM
oldveeracer's Avatar
oldveeracer
Default Reduced air flow in all HVAC modes
2006 Ram 1500 (Night Runner) quad cab...switched to DEFROST mode one day and heard a "clunk" on right side of dash. All modes/intermediate positions work using rotary switch but air flow is drastically reduced for each function and the fan is overworking/strained. Same lack of flow in NORM or RECIRC. Any ideas; will this require a dash "lobotomy? Think that flow must be partially blocked near the blower outlet ??
Also, any idea how many Night Runners were produced? Have only seen (3) in the past 10 years with travels through most states east of the Mississippi.
THANKS
Old Apr 8, 2019 | 07:14 AM
catfish621's Avatar
catfish621
Remove the fan motor. Reach up into hole and you will feel the recirc door which has broken. Remove door and reassemble. I didn't bother replacing the door.
Old Apr 8, 2019 | 08:21 PM
fj5gtx's Avatar
fj5gtx
I did the same on my 2004 1500. I still have the replacement door with steel shaft from Dorman in the stash... who'd know I'd end up with another 2004 years later.
https://www.dormanproducts.com/p-52074-902-325.aspx
Old Apr 9, 2019 | 06:57 PM
72rtchallenger's Avatar
72rtchallenger
It sounds like recirc door and not hard to replace and a quick fix ,,but if any of the other 4 doors break then its time to drop dash an they will eventually break, as its a known problem ,
My truck recirc door broke followed by 2 more of the other blend doors in a year or so according to previous owner so I replaced all when I bought truck , Its not that hard to drop the dash and replace all 5 blend doors , I dropped my dash out in a just over an hour , did not have to drop steering column only drop down and pulled dash an laid it over in front seat as I did not have helper to take out ,but then had access to the heater box ,an had that out in about another hour , of course you need to unhook heater hoses an A/C lines and lose the Freon but far easier than some do by cutting the heater box up to replace the doors , I did mine in 4 to 6 hours and back together ,but I was prepared with a good research an instructional video on you tube an proper tools and all parts at hand and then charged the A/C a few days later,,hardest thing is the panel that is the plastic cover over defrost outlets an is across front part of dash , be careful as it needs to lift an pull towards you at same time to be removed , pry easily , it becomes brittle over time out in sun , can be replaced but not cheap unless you find used one
