Fuse 51 instrument cluster and horn
Old Apr 9, 2019 | 12:26 PM
odoml's Avatar
odoml
Default Fuse 51 instrument cluster and horn
2004 Dodge Ram 1500, 5.7 Hemi - Does anyone know which/if control module (ECM, PCM, or other acronymn) is in this circuit? I have found that a faulty steering wheel horn switch will short to ground (through fuse 51) even when the horn fuse is pulled. I just found this and have been disconnecting the battery at night to keep from completly draining the battery. Now my gauges go out including the odometer from time to time even thought the engine will continue to run (thankfully). When the gages go out the odometer displays "no bus". I am thinking there is an instrument cluster module somewhere that this short has damaged. I would like to replace it before the engine dies.
Thanks,
OdomL
