Water pump replacement
Old Apr 10, 2019 | 11:19 PM
CDieterich's Avatar
CDieterich
Default Water pump replacement
Hi all!
Recently, the water pump on my 2006 Dodge 1500 (3.7 L V6) has started leaking coolant onto the belt pulley, causing a lot of slip. Should I go to O'Reillys or RockAuto for a replacement, or am I better off with an OEM part? I want to avoid replacing this thing every couple years.
Old Apr 11, 2019 | 06:58 AM
fj5gtx's Avatar
fj5gtx
AdvanceAuto seems to have a decent pump for the 5.7, probably the same quality with the 3.7. But these days, everything is a knock off china manufactured part.
Old Apr 11, 2019 | 07:43 AM
ZEN357's Avatar
ZEN357
Originally Posted by CDieterich
Hi all!
I normally go to Advance Auto Parts, but really any reputable Auto Parts store should have a good quality water pump. AutoZone, O'Reilly's, Advance Auto, or RockAuto. I guess it's all in what you want to spend. If you are looking for a higher end Water pump you could check with Summit Racing or Jegs.
Old Apr 11, 2019 | 10:02 PM
72rtchallenger's Avatar
72rtchallenger
Napa has better quality or buy oem from Dodge , Mopar always better in general
