07 Accessing pax-side rear coil pack? (pic)
Old Apr 28, 2019 | 12:30 PM
CMA's Avatar
CMA
Default 07 Accessing pax-side rear coil pack? (pic)
Almost finished with spark plug change at 60K. I either need a shallower socket, or a way to move the water lines above the coil pack.
There is a plastic connector on the firewall holding the lines in place, was wondering if there is a special tool that allows to remove this?
If I get a shallower 10mm socket so I can move under the water lines, I still need to remove the coil pack... so it looks like the best way is to move the water lines.
Any advice appreciated.
Old Apr 28, 2019 | 01:32 PM
72rtchallenger's Avatar
72rtchallenger
If your talking about the long black nozzle looking clip, it just slides over threaded bolt sticking out of the firewall , I think it just pulls off
Old Apr 28, 2019 | 01:55 PM
CMA's Avatar
CMA
Yes, that one. I'll play with it and see if it moves.
Old Apr 28, 2019 | 08:46 PM
CMA's Avatar
CMA
Doesnt seem to move. Any ideas?
Old Apr 28, 2019 | 09:03 PM
Open the clip where it holds on to the hoses, then it should thread off.
Old Apr 30, 2019 | 08:48 PM
davb673's Avatar
davb673
I think that is what I did. It's been a while since I checked the plugs, and I've slept since then... I'd previously moved so much stuff to swap in my HO cams, that it didn't seem so bad just pulling the coil pack.
