Which front hub assembly
Old May 19, 2019 | 11:16 AM
mopar4u's Avatar
mopar4u
Default Which front hub assembly
05 ram 4x4 slt reg cab short box
Im getting ready to do the two front bearing hub assemblies. Little confused on the abs situation.
i have a wire going to the drivers side front hub. No wire going to the passenger hub. I believe this means i have 2 wheel abs.
speaking in terms of moog part numbers, there is 515072 which is for 2 wheel abs. I went into advance auto and saw that there is no wire on this hub. Moog also has 515073 which is listed for 4 wheel abs. Pictures show this part having the wire.
my question is if im doing both front hubs do i need 1 of each part number even though the 515073 says its for 4 wheel abs?
Old May 19, 2019 | 07:55 PM
I think the PCM uses the left front speed sensor for both the speedometer, and cruise control. So, I would expect one of each.
Old May 20, 2019 | 08:25 PM
72rtchallenger's Avatar
72rtchallenger
some info at this thread https://dodgeforum.com/forum/2nd-gen...ck-breaks.html
