P0307-Misfire Cylinder 7 2002 Ram 1500 4.7l 4x4 190,000 miles
Old May 25, 2019 | 10:26 PM
jencoffelt's Avatar
jencoffelt
Default P0307-Misfire Cylinder 7 2002 Ram 1500 4.7l 4x4 190,000 miles
I need suggestions/advice please.
Coil in cylinder 7 and all plugs changed a week ago. Code has returned today. Idle is way too high, cold start between 1200 and 1500 RPM without dropping even if I let it warm up. Will also rev up and down on its own while idling. The TPS was changed 2 days ago and the throttle body cleaned without removing. I am trying to avoid a shop if at all possible. I need ideas on what to check/change next. Any advice will be greatly appreciated!
Old May 26, 2019 | 08:12 AM
You have a vacuum leak.
Old May 26, 2019 | 06:57 PM
72rtchallenger's Avatar
72rtchallenger
I agree , look for vacuum leak
Old May 27, 2019 | 04:39 AM
jencoffelt's Avatar
jencoffelt
Thanks y'all. I will do that.
