ABS and Brake light on
Old May 31, 2019 | 05:11 PM
Steelman66's Avatar
Steelman66
Default ABS and Brake light on
I had the all too familiar ABS and Brake lights on the dash on my 2004 Ram. Mine went further by causing the truck to stall at lights. Speed sensor (rearend, fuses) not fixed. My mechanic said all the codes pointed at the ABS module. When he removed the original unit, it fell apart in his hands. Two things. 1) there are sites on the web that state they can rebuild your unit, thereby bypassing the flashing portion of the replacement ($99-$120). I of course have the TRW brand (yes it's the factory unit) which nobody rebuilds. 2) The ABS module for my 2004 is obsolete. I managed to find one on Rockauto's site, relatively cheap. Took it to him and WALA! I'm on the road again. Thought I'd pass this along
Old May 31, 2019 | 08:23 PM
fj5gtx's Avatar
fj5gtx
That is a good find, congrats !
Old Mar 30, 2024 | 02:55 PM
Tillvalhalla1488's Avatar
Tillvalhalla1488
My 04 ram 5.7 is doing the same thing. Stalling on me all of a.sudden never had the problem now it's everyday problem. It will run for five mins on its own till it stalls out and has abs warning and brake warning light. No codes. Replaced the brake switch checked grounds and corroded wires replaced them cleaned my TB. It's brake related. If I hold the brake it will run for hours. So I thought the brake switch now seeing the entire abs unit on these is a problem themselves
Old Mar 30, 2024 | 03:37 PM
Is your truck throttle by wire? Or is there an actual cable going to the throttle body?
