2005 Ram 1500 5.7 Oil Leak
Old Jun 3, 2019 | 10:39 AM
KDClarke's Avatar
KDClarke
Default 2005 Ram 1500 5.7 Oil Leak
My Ram just turned 200k miles and has developed a leak near the crankshaft seal. However I can't determine if the oil pan is leaking or the crank seal because it doesn't do it in the driveway, only when driving. It's losing @ 1/8 to 1/4 of a quart at a time. Any suggestions to pin it down?
Old Jun 3, 2019 | 03:01 PM
Front, or rear?
Old Jun 3, 2019 | 07:17 PM
KDClarke's Avatar
KDClarke
Front. Always had normal oil changes, never had a leak until I sent the wife a pic of the odometer turning over. I'm meticulous about keeping up on the maintenance so it surprised me when it suddenly started. I've cleaned the front of the engine a few times now and like i said in the driveway nothing. On the road when I get to work I have oil dripping after about 7-10 miles.
Old Jun 3, 2019 | 07:38 PM
Change the front crank seal. It is inexpensive, and "easy" (as these things go.....)
Old Jun 8, 2019 | 09:25 AM
72rtchallenger's Avatar
72rtchallenger
Have you ever replaced the PCV valve ? I would at least check it an make sure its not gummed up , One job of the PCV valve is to reduce crankcase pressure. A PCV valve that is clogged or stuck in the closed position will allow crankcase pressure to build . This can cause the oil to leak through gaskets and seals. It can also force oil into the air cleaner assembly.
