52121036AG evap mod
Old Jun 27, 2019 | 07:53 PM
TejasMtnBiker's Avatar
TejasMtnBiker
Default 52121036AG evap mod
Thoroughly looked thru all the posts/threads/pics etc. anyone have a mod for this, other then jb welding it to the canister with pex! lol
Old Jun 27, 2019 | 08:11 PM
primem's Avatar
primem
post a link to what you are referring to
Old Jun 27, 2019 | 08:55 PM
TejasMtnBiker
see #7, rubber just doesn't last as it elbows 2 into 1 on top of canister, used zip ties lasted about 6 months even slathered with silicon rtv. When i hooked my smoke pump to it leaks in this area every time right before inspections due https://www.moparpart.com/v-2004-dod...rtrain-control
Old Jun 28, 2019 | 09:38 AM
primem's Avatar
primem
what year is the vehicle? What codes are setting?
smoke pump; are you referring to the vehicles leak detection pump, a homemade smoke machine or store bought evap leak detection equipment?
if you have a homemade smoke machine; how much pressure does it put out. if to high the system will leak. smoke machines should only generate approx. 6 psi pressure.
