2003 Ram 1500 12V Power Outlet Failure
Old Jul 25, 2019 | 12:45 PM
VetFire17's Avatar
VetFire17
Default 2003 Ram 1500 12V Power Outlet Failure
The 12V power outlet below the ashtray stopped working after using it with an air pump. I have checked every fuse under the hood I can find related to it and none of them are blown. Any suggestions?
Old Jul 25, 2019 | 02:58 PM
TrueDogman's Avatar
TrueDogman
Check fuses in side of dash after opening drivers door
Old Jul 25, 2019 | 05:20 PM
Alex Medeiros's Avatar
Alex Medeiros
I'd also check there. Many people don't even know there are fuses there
Old Jul 25, 2019 | 08:58 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
If all the fuses are good, pull the connector off and put a meter to it; should be 12v constant. If it has 12v then the outlet took a ****, it happens, especially considering the truck is 16yrs old.
