2007 ram 1500 (Driver Seat)
Seat moves back and forth, reclines both ways. Up and down doesn't work. I have read that motors cannot be replaced individually that you have to replace the whole power track. Wondering if this is true. Need an answer please.
Check with various online parts suppliers. If the motors are available individually, it should show in the parts diagram. Other option would be to find a compatible motor in the junkyard, and just score a couple of those. (just in case.
Pretty sure MoPar doesn't sell the individual motors. But they are just mounted in there with a spring tension pin, that you can knock out and remove the motor. Your problem could be the switch, motor, wiring, or jammed seat mechanism. Gotta start diagnosis to determine your root issue.
