Ignition gremlins
Old Nov 3, 2019 | 02:23 PM
timdirt's Avatar
timdirt
Default Ignition gremlins
When truck is off volt gas temp and oil pressure all flip up to center and move and buzz which is annoying as hell. You push the key in and it stops but does it again I started with a new ignition switch and it hasn’t fixed the issues. Accessory position doesn’t work either unless you push the key in. Anyone else had this problem if I don’t drive the truck daily it will kill the battery. And not really sure what I’d be looking at to replace next in the column itself to remedy the problem.
