3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Yes and no .. I've looked behind the radio and everything seems intact.. there's not even much back there...
can someone please help me pinpoint this issue
Were all the lights working prior to you changing the radio? Trying to get the backstory and see what could've caused this issue to occur for you.
I'd really appreciate if someone could help me pinpoint this, I don't know what connects where to even check, but the fuses are good and have been swapped etc..
Very interested in this thread as none of my interior lights are working either.
Biggest difference - I don't have an aftermarket stereo and fuse #35 keeps blowing. Thus, I know I have a short or something somewhere, but I'm not a good electrical troubleshooter.
Similar issue on my 1996 ram van b3500. Was wiring interior light when ground and pow touched sparked and no more light. thought i heard a pop but went to check the fuses and they all check out. Anyone know if there is a separate location for interior lights? Tested the relay and that is working when i activate the switch to the lights.
Hey bro, my problem happened to be a broken wire UNDERNEATH the fuse box under the hood..he loosened the fuse box lifted it up and underneath you could see one broken wire, turns out it was the wire for all my interior lights lol.
