Fuse Panel?
Old Dec 16, 2005 | 11:42 PM
bcashm's Avatar
bcashm
Default Fuse Panel?
Does anyone know if there is another fuse panel in an 02 Ram besides the main under the hood by the battery? I see nothing to do with brake lights in that fuse box.
Old Dec 17, 2005 | 01:30 AM
glock45's Avatar
glock45
Default RE: Fuse Panel?
I have the skematics for the 02 what specifically are you looking for in regards to the brake lights?
Old Dec 17, 2005 | 01:48 AM
bcashm's Avatar
bcashm
Hi Glock, Here's the deal. There are 4 brake light bulbs. Two on each side. They have 9 volts with the running lights turned on and 12 volts when you push the brake, or use the turn signals. The top bulb acts as the blinker on each side. The driverside top bulb gets its 9 volts when the lights are on, and its 12 with the blinker. But remains 9 for the brake, doesn't get brighter. So my question is, am I missing a fuse panel, because I don't see anything for the brake lights under the hood. Or is there a transmitter or relay somewhere that could possibly have went bad. thx Bill
