Brakes issue ... deep down the rabbit hole...
Old Nov 27, 2019 | 03:07 PM
firedogg's Avatar
firedogg
Originally Posted by primem
don't laugh cause I've seen it... are all the calipers installed on the correct side...if the bleeder screws are at the bottom you will never get the air out.
Hey guys... just wanted to provide an update to you all. THANKS SO MUCH for the input. I did indeed bleed the brakes according to the manual and all that...the fronts were correct, but what was INCORRECT on our part is we/I did install the back calipers on the wrong side...that is to say the bleeder valves were on the bottom...I took them off this am, switched this am - did normal bleeding procedures and I have a firm pedal back. I couldn't get my ABS to activate on my gravel road...so I still may have to investigate that and have him bring back his diagnostic tool to test / activate the ABS system.
Thanks again...fundamentals first....
Cheers all! You can guarantee I'll check that EVERY time now on any brake job.....nipples up!!
Special thanks to PRIMEM! So this makes #3 for your caliper input being on point!
