2002 5.9 stuck 3rd in D range.
Old Dec 20, 2019 | 12:08 AM
Ryo jp's Avatar
Ryo jp
Unhappy 2002 5.9 stuck 3rd in D range.
Hello from Japan,My 2002 Dodge Ram 5.9 transmission problem.No error, but starts from 3rd in D range.
In manual shift 1-2-D3-D4-OD works without any problem.
The check light is only SIR (P1200 output driver).Is this limp home?
No one fix this car in Japan.
Thank you for everything.
Old Dec 20, 2019 | 10:31 AM
TrueDogman's Avatar
TrueDogman
Sounds like you have an issue with the valve body. Sorry Im not sure if that year uses solenoids??
Old Dec 21, 2019 | 09:26 PM
Ryo jp's Avatar
Ryo jp
Thank you for the reply.My 46RE works on governors, solenoids, and sensors.
I will first replase them. but, in case of wrong I will try fix valve body,
