Cab swap
Old Dec 28, 2019 | 10:38 AM
Frank04's Avatar
Frank04
Default Cab swap
I have an 04 1500 quad cab 4wd and I’m researching a cab swap since mine is rusted out. I found a cab at a really good price by it’s a rwd.
My question is will I have any problems swapping my cab with a cab that was on a rwd? I know I need to cut a hole for the stick in the floor. I’m not sure if I will have to cut anything else.
Any advice would be awesome.
Old Dec 28, 2019 | 04:52 PM
fj5gtx's Avatar
fj5gtx
wiring harness could be a problem, there are changes across the years and sometimes options.
Old Dec 28, 2019 | 06:49 PM
Frank04's Avatar
Frank04
ya I plan on swapping the wiring as it’s a cab from an 05. Just worried about clearance for the transfer case.
Old Dec 29, 2019 | 02:49 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Sheet metal is all the same, if you look at the passenger front floor on both you can see the hump kick out for it (blue circle, this is a 2wd):
Old Dec 29, 2019 | 09:52 AM
Frank04's Avatar
Frank04
awesome thank you. I was thinking it should be interchangeable but the guy I’m buying from wasn’t sure.
thanks for the help!
