No start. PCM?
Old Jan 5, 2020 | 07:10 PM
  #21
primem's Avatar
primem
the yellow wire is the power out that feeds the relay so the red "in"wire must be good...disconnect the battery....ohm check the wire from the yellow wire to the relay pin.
Old Jan 5, 2020 | 07:52 PM
  #22
Jkdub's Avatar
Jkdub
Went ahead and tried replacing the ignition switch and still nothing happened. If what you say doesn’t have to do with the ignition switch, I’ll try that next.
