2005 ram 1500 4.7 p0430
Old Jan 20, 2020 | 03:52 PM
Bret1996's Avatar
Bret1996
Default 2005 ram 1500 4.7 p0340
Truck will start sometimes and won’t start others. Replaced cam and crank sensors. Replaced battery and spark plugs. I’ve replace the cam sensor 3 times already and have checked the wiring it seems fine I got voltage. I’m super lost and can’t figure this out. I’ve read other forums and still no help. I tried replace the pcm as well.
Old Jan 20, 2020 | 04:04 PM
72rtchallenger's Avatar
72rtchallenger
That p0430 is related to catalytic converters I believe , perhaps its getting clogged up,,I would research some more on that code ,,might be wiring to 02 sensor , usually bank 2,,but the engine not starting might be clogged cat,,but maybe someone else will chime in with more advice
Old Jan 20, 2020 | 05:06 PM
Bret1996's Avatar
Bret1996
My bad wrong code p0340 is what I have
Old Jan 20, 2020 | 05:39 PM
72rtchallenger
One possibility is its in the timing chain, something could be worn throwing off how the sensor is reading it
Old Jan 20, 2020 | 06:05 PM
Bret1996's Avatar
Bret1996
I don’t think so I had the chain and tensioner done 2 years ago about 5000 miles.
Old Jan 20, 2020 | 06:13 PM
72rtchallenger
You may be right but that's about the only other thing other than bad wiring to the plug on cam sensor , even 2 years nothing is a guarantee
Old Jan 20, 2020 | 06:18 PM
72rtchallenger
put a timing light on it when it is running
Old Jan 20, 2020 | 07:00 PM
72rtchallenger
Maybe pull the sensor and see if there is oil or build up on the area its suppose to read ?
