No dome lights, power mirrors, cruise
Old Feb 25, 2020 | 02:43 PM
geomastro's Avatar
geomastro
Default No dome lights, power mirrors, cruise
All,
I recently bought a 2003 Ram 2400 QC 4x4 Hemi long bed. Truck was neglected & not running well when i bought it, so it was a bit of a project. I installed a new injector, timing chain, oil pump, oil pan, water pump, plugs, wires, etc. Truck is running great now, but trying to fix some of the "small" annoying problems I have discovered along the way. I don't know how or if any of the below are related to each other:
  • The interior dome lights do not work. None. Doesn't matter if key is on or not, manually push them or if any door is open or if headlight interior switch is rolled to turn them on. Nothing. Bulbs are good as are all the fuses associated with it in the fuse box under the hood. Nor dose the cargo light.
  • The power mirrors don't work. I replaced the door master switch for the window and locks because the it was stuck in "window lock" position. New switch solved that problem, but had no effect on power mirrors. Again, all fuses are good.
  • The cruise control does not work at all. Light doesn't come on when "set". (not convinced that this is related at all)
  • The overhead console display is reset every time the truck is tuned off. That is, the average fuel economy is 0.0 every time i turn the truck on. No memory.
  • Everything else seems to work fine. Radio (oem), power windows, locks, cluster lights (they dim properly also), power outlet, heater motor, heated mirrors,etc. are all good
I'd appreciate any troubleshooting tips. I've done a ton of internet research recently on fcm, ipm, iod fuses, ctm, etc. It's all very vague. Looking for a good place to start from someone who's seen this type of issue and a way to validate findings.
Old Feb 26, 2020 | 07:49 PM
72rtchallenger's Avatar
72rtchallenger
Hard to say for sure , I would clean all the grounds an maybe try to clear everything by resetting the pcm maybe , unhook the battery cables an tape them together overnight and see if it helps clear any issues ,,perhaps remove the fuse box underhood and clean all the contacts an plugs underside of fuse box , check for corrosion of anything in that area including the module that mounts on side of fuse box as it controls most lighting ,,maybe check the ignition switch as I have heard of issues with it that may be related ,,good luck as it most cases you need to trace backwards in wiring to find out why there is a loss of power to a certain wire feeding it all ,,and electrical gremlins suck
