power window
Old Mar 1, 2020 | 02:48 AM
WOOTEN's Avatar
WOOTEN
Default power window
So Im having a wired problem with the passenger side power windows. from the drive side switch I can roll down the front and back passenger window fine, but I can only roll them up together. They do go up and down just fine from there own switches. I have replaced the driver switch thinking that it was the problem but I am still having the same problem. What do you all think?
Old Mar 1, 2020 | 01:03 PM
Alex Medeiros's Avatar
Alex Medeiros
Sounds like a loose connection, or an issue with some of the wires. My dad had a very similiar issue where sometimes the passenger window wouldn't work off of the passenger side switch so it had to be controlled through the driver's switch. Try cleaning the plugs that go into the switches, maybe that'll help.
