Weird Judder When Taking off
Old Mar 12, 2020 | 06:46 PM
ProStreetDriver's Avatar
ProStreetDriver
Default Weird Judder When Taking off
06 1500 4x4 5.7L, just got the truck not too long ago and it's been doing this weird judder lately. New pads and rotors, rebuilt the front calipers, brake fluid flush, new slide pin bushings, no codes, and new rear ABS sensor. After about 20min of driving, it doesn't always happen, I come to a complete stop and it gives this weird judder taking off. Almost as if the brakes are sticking. It'll do it in reverse too and it seems to be a bit more prominent there. So I took everything apart, checked the pads and hit them with some sandpaper, sanded the rotors too thinking there was some material built up causing them to stick. Checked the pistons, pushed them out and then pushed them back in. Doesn't seem like they're sticking. Pads and pins move freely, still can't figure it out. Any ideas?
Old Mar 13, 2020 | 11:11 AM
TrueDogman's Avatar
TrueDogman
Could be a driveline issue. Seized u joint comes to mind.
Old Mar 13, 2020 | 04:43 PM
72rtchallenger's Avatar
72rtchallenger
I have an 04 4x4 ram that does something similar , feels weird as you take off in drive or in reverse just for a sec and not every time , I haven't located the issue yet as its running driving an I am rebuilding a 79 f100 so haven't torn into it yet , but hope to soon as mine has new brakes ect an no codes,,and u - joints are good as well,,if I find out soon I will post
Old Mar 18, 2020 | 08:05 PM
big guy's Avatar
big guy
When I had similar problem turned out to be worn out rear yoke.
