05 ram 4.7 v8 won't rev past 2500
Old Mar 11, 2020 | 08:03 PM
Meg Jeff's Avatar
Meg Jeff
Default 05 ram 4.7 v8 won't rev past 2500
have had a number of issues with the truck and just replaced the motor with an 06 durango. Now I can't get the rpms over 2500. Cleaned the map sensor, changed fuel pump and fuel lines, and still not running properly. Any help is appreciated.
Old Mar 11, 2020 | 08:37 PM
Moving this to third gen ram section.
Old Mar 11, 2020 | 09:10 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
1. In gear or in neutral?
2. If in gear, did you check to ensure the crank tone wheel tooth count was the same, or found the first affordable 4.7 you could find and dropped it in? 2005 Ram is still a PCI bus system, Durango had already gone to CAN bus by 2004.
Old Mar 17, 2020 | 08:17 PM
Meg Jeff's Avatar
Meg Jeff
In gear and in neutral.and yes, we found the only motor within our budget and dropped it in.
Old Mar 17, 2020 | 09:46 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
So you didn't bother check if it would work properly first....
Old Mar 17, 2020 | 10:42 PM
Meg Jeff's Avatar
Meg Jeff
Yes I did. The place I purchased it from insured me that it would work.i asked dif I could take the computer from the doner truck and he told me it would make no difference I didn't need to. It drive like a brand new truck for about 3 days. And then everything started to go wrong ot seemed. Random codes and like 13 ata time.
Old Mar 18, 2020 | 08:18 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
What codes?
Old Mar 18, 2020 | 12:33 PM
Meg Jeff's Avatar
Meg Jeff
P0202
and p0302
Are the only ones on there at the moment.
Old Mar 18, 2020 | 11:16 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
P0202* Injector #2 Control Circuit
P0302* Cylinder #2 Misfire
I'd start with cylinder #2
