05 Ram 5.9 vibrations while driving
Old May 23, 2020 | 02:35 AM
Dan2500's Avatar
Dan2500
Default 05 Ram 5.9 vibrations while driving
Looking for advice. Today while driving my truck I noticed a vibration around 25-30 mph. When I let off it goes away. 1 piece driveline so no carrier barring u- joints seem tight. When I let off and accelerate I can hear a “clunk”. The only thing that seems like it may be an issue is the rubber mount under the transfer case, mounted to the cross member. Seem like there is a lot of flex to it. Any ideas? Rear end maybe? Transfer case maybe? I’m completely stumped and don’t want to throw bunch of money at it without knowing.
Old May 23, 2020 | 09:50 AM
TrueDogman's Avatar
TrueDogman
First thing I would do is pull drive shaft out and check u joints.
Old May 24, 2020 | 10:20 AM
Dan2500's Avatar
Dan2500
Default Fixed!
Ended
Ended up being a u joint 🤦‍♂️
Old May 24, 2020 | 10:25 AM
lxman1's Avatar
lxman1
Site Moderator
Thanks for the update.
Old May 24, 2020 | 11:14 AM
95RAM360's Avatar
95RAM360
How did u check the u joints? I’ve seen some that look ok, no play but once pressed out the caps were cracked and needle bearings straight seized. Get a big pry bar and wedge in to move caps....at least a 24inch prybar. Sometimes you need a lot of leverage to Find the play
