Front Door Wiring Harness
Old Jun 1, 2020 | 05:25 PM
forseys's Avatar
forseys
Question Front Door Wiring Harness
I have a 2006 Dodge Ram 1500. The part I am looking for is a female disconnect terminal that goes inside the housing of the wiring harness that connects to the master switch. Since I can't find a terminal the same size I could just buy the whole harness (part number 56051935AB) but it is discontinued. Does anyone know where I can either find a terminal disconnect or a wiring harness with the same size disconnects that I can take out and use?
Housing for the terminals
female disconnect terminal that needs to be replaced.
Old Jun 1, 2020 | 09:21 PM
fj5gtx's Avatar
fj5gtx
What I did, was grab a junk yard harness, de-pin the color I wanted and swap that wire. I had a tough time on the de-pin of the harness where it connects at the cab - ended up buying specialized pin tools that the factory service manual suggests. That connector might de-pin with normal tools...
Old Jun 8, 2020 | 07:46 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
http://connectors.dcctools.com/home....A972DDCBDF9F62
Old Jun 8, 2020 | 08:18 PM
TrueDogman's Avatar
TrueDogman
Weedahoe is back! Good to cya !! 😊
Old Jun 15, 2020 | 08:36 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Thanks. I drift in from time to time but I spend so much time out of town on different job sites now that I dont care to get online much these days when i have down time
