Changed differential fluid and found........
Old Aug 11, 2020 | 07:42 PM
theuscfan04's Avatar
theuscfan04
Default Changed differential fluid and found........
So changed my 05 (2wd) differential fluid and found a couple of pieces of something that looks like some kind of clip or something.
Any ideas?
Old Aug 12, 2020 | 12:31 AM
theuscfan04
Looks to be a tracloc guide clip.
Old Aug 12, 2020 | 09:25 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Living on borrowed time now if you have the stock limited slip lol. Google "Dodge Ram C clip failure". It's a misnomer, it's not the actual "C clip" that retains the axle itself but a piece from inside the differential.
Old Aug 12, 2020 | 08:07 PM
fj5gtx's Avatar
fj5gtx
Yep -, this is one of a few reasons I switched over to 3/4 ton and will never go back to 1/2 ton dodge. The larger issue is the piece that remains is now loose and likely grinding a groove in the axle housing that a machinist would be proud of.... I removed the remaining piece from mine so it wouldn't totally kill the axle housing.
