A/C Condenser Fan Turning On Randomly
Old Aug 13, 2020 | 07:36 PM
grpht03ram's Avatar
grpht03ram
Default A/C Condenser Fan Turning On Randomly
I noticed the fan turns on when the HVAC system is off
it only seems to happen when engine coolant temps are ~220
Is this programmed in the computer to help engine cooling? I don't even think that fan can cool the engine
I swapped relays. Fan still turned on
I have a 2003 with the 4.7L
Thanks
Old Aug 13, 2020 | 09:31 PM
Probably programmed to behave that way.
Old Aug 13, 2020 | 09:56 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Should only be one electric fan on the A/C condenser. It wouldn't do any good for the engine anyway. When you say HVAC off, do you mean the whole actual system (fan off, nothing lit up) or do you mean just the A/C portion? Is it on defrost at any point with any fan setting on?
Old Aug 21, 2020 | 08:34 PM
grpht03ram's Avatar
grpht03ram
Update: A new fan motor fixed the problem
I installed Four Seasons part # 35077
I read bad reviews of the other aftermarket fan motors, mainly fitment problems
The 4 Seasons is made in Canada. Seemed very good quality and the fitment was perfect
