Torque converter?
Old Sep 20, 2020 | 04:30 PM
posd2004's Avatar
posd2004
Default Torque converter?
04 ram 1500 5.7 started making grinding noise few days ago so I jacked up the rear end and put it in neutral and got under it and had a friend spin the tires. I heard noise from directly in the trans oil pan almost like a bad bearing but I can’t find anything online. The noise is only there when the truck is moving. There’s no slipping gears or hard shifting so I’m not sure if what I read online it’s the torque converter or actually because of the differential. I just rebuilt the diff about 3 months and about 5000k ago. I’ve checked fluid frequently so it’s not too low or too high. Any advice would be greatly appreciated.
Thanks
Old Sep 20, 2020 | 08:37 PM
If it's loudest in the pan, you may have a bearing IN the trans that is going out. Wouldn't hurt to drop the pan, and see if you find anything interesting in there.
Old Sep 20, 2020 | 09:51 PM
posd2004's Avatar
posd2004
Yea I’m gonna try to do that tomorrow. Also a slight rattle has started as well when I am braking and just at the last 15-20 feet is where I hear it. Just sounds like a cattle bell. Not sure if that’s related or not.
