Window Lockout
Does anyone know offhand what wires to jump in the drivers side kick panel to bypass the window lockout on the driver door? The switch doesn't work so the passenger window won't work from the passenger side.
The drivers control switch pops out of the door panel very easy. all you need is a flat blade screwdriver to gently pry up on it. that will give you access to all the wires on the switch.
2004 Regular Cab Power window -- bypass the lockout part of the switch
The way I read the schematic, you should jumper between pin 9 on C1 (blue 12 way connector, PK/YL wire - fused switch power) and pin 8 on C2 (blue 8 way connector, R/LB wire - power window switch feed)
I'm not sure how to post pictures just yet, but I can email them to you if you need.
Israel
Israel
