Speedometer issues
Old Oct 22, 2020 | 09:41 AM
Jeff Bombyk's Avatar
Jeff Bombyk
Default Speedometer issues
2004 ram speedometer doesn't work. ABS light is on. Brake light is flashing. Have replaced the sensor on differential and output shaft . Repaired wiring to rear speed sensor and checked fuses and plug at ABS unit. I'm going check the inside of fuse box next. Any other suggestions?
Old Oct 22, 2020 | 10:20 AM
Get the codes read, and see what it is whining about.
Old Oct 22, 2020 | 12:40 PM
Jeff Bombyk
No codes. The only thing my scanner shows is speed sensor A out of range.
Old Oct 22, 2020 | 01:21 PM
That will annoy the ABS and brake systems as well. They really want to know how fast you are going.
On yours, doesn't the PCM gets its vehicle speed clue from the left front wheel speed sensor?
Old Oct 23, 2020 | 09:39 AM
Jeff Bombyk
I don't no can't find a good diagram of speedometer or cruise systems. I assumed it got it's speed signal from the rear sensor. But I will check the front wheel speed sensor. Thanks.
Old Oct 23, 2020 | 10:21 AM
Ok, according to what I am finding, the sensor on top of the rear diff also feeds the speedometer. If you have already replaced that once..... Might be tempted to warranty swap it, and if the problem persists, then you need to check the wiring to the sensor.
Old Oct 24, 2020 | 09:59 PM
Jeff Bombyk
I've already warranted it once and done a continuity test of the wires. I have repaired an abrasion of the insulation.
. Can the abs controller interfere with the speedometer ?
Old Oct 24, 2020 | 10:00 PM
Don't know.... I don't have wiring diagrams for your truck.....
Old Oct 25, 2020 | 12:24 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
http://www.mediafire.com/file/8k5u7y...anual.pdf/file
