Nv3500 first and second gear sound like I’m turning at 7,000 rpm when I’m going 2,000
Old Nov 29, 2020 | 06:24 PM
Stone Norton's Avatar
Stone Norton
Default Nv3500 first and second gear sound like I’m turning at 7,000 rpm when I’m going 2,000
I replaced pressure plate throwout bearing pilot bearing clutch disk, I didn’t change the input shaft bearing because it seemed to be fine. Some of the noise it was making before definitely got better the throwout and pilot bearings were both broken, but now when I’m in first or second gear and I get to around 2,000 rpms it sounds like it’s going to blow up it just sounds like it’s going “fast” if that makes any sense, I really don’t what to think, I’m assuming it’s not normal I guess I could go back into it and change the input bearing as that’s the only thing left
