Pcm help please
Old Dec 17, 2020 | 10:42 PM
pcm crazy's Avatar
pcm crazy
Default Pcm help please
Ok i made the mistake of turning in my factory pcm as a core for my new one i did not write software # down and parts store which knew less than i did about this sold me the wrong pcm and now i have no pcm or a way to get my software # to get an aftermarket one is there any other option for me its an 05 ram 5.7l
Old Dec 18, 2020 | 08:55 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Have your local dealer run your VIN to get the correct one.
Old Dec 18, 2020 | 09:10 AM
pcm crazy's Avatar
pcm crazy
Have tried every dealer around me none can give me the software # and aftermarket people keep telling me theres 12 or more different pcm that match my oem part # i have the part # from dealer but they say i need the software # im lost lol
Old Dec 18, 2020 | 11:25 AM
You should be able to take your truck to the dealer, they plug in their tools, and can flash it to whatever software revision is required.
Old Dec 18, 2020 | 01:22 PM
pcm crazy's Avatar
pcm crazy
I took it to dealership with the pcm from parts store they couldnt even flash my vin on it. I can buy one from dealership for 1300 plus cost of having it towed there around 400 and they told me they couldnt garentee that the one they ordered would be the right one
Old Dec 18, 2020 | 03:25 PM
Someone doesn't have a clue. (at the dealership) Part number on the PCM is what is important, the programming is all flashable. They need the whole truck, with PCM installed to do it though. Your truck should run fine if the programming is even close.... (correct motor/trans combo) just SRS and ABS won't be happy. If the truck won't start with the new PCM, then the PCM has a problem.
