No Heater Blower
Old Jan 10, 2021 | 06:44 PM
HemiMoparGuy1981's Avatar
HemiMoparGuy1981
Default No Heater Blower
Hey guys, looking for ideas of common issue before I go crawling under my dash...at 6'3" 300 lbs I don't want to contortion myself unnecessarily. I replaced the controller figuring it to be the culprit since it definitely had power, as it worked intermittently and the A/C indicator would illuminate as I pressed it, even with blower switch off, so I figured the switch to be bad and not making contact, so the A/C doesn't know not to turn on without the blower. I know it's not impossible, but the blower motor has been replaced. Another concern, and reason I don't want to squeeze under the dash with a meter quite yet is the lamps don't light up when headlights are on...old unit several bulbs were visibly burnt out, but for the new ones to also not work, and NONE of them working makes me think there could still be something else besides blower motor or resistor.
Any help will be greatly appreciated.
Thank You
Old Jan 10, 2021 | 11:42 PM
Alex Medeiros's Avatar
Alex Medeiros
Have you checked the blower motor resistor?
Old Jan 11, 2021 | 06:05 AM
ol' grouch's Avatar
ol' grouch
Thank You
I've never replaced one on a 2nd Gen, but the heater blower resistor is the most common issue to cause this. Older trucks have wires that will burn out. Newer ones are a sealed block that can melt. What will happen is you only have high speed when it starts to fail. Then it will quit altogether. The solid state one I replaced was on a Jeep but it would sometimes work if you wiggle the wires. When I got it out, it was visibly melted.
Last edited by ol' grouch; Jan 11, 2021 at 01:14 PM. Reason: i kant spel wurth a durn
Old Jan 11, 2021 | 08:57 AM
HemiMoparGuy1981
I've never replaced one on a 2nd Gen, but the heater blower resistor is the most common issue to cause this. Older trucks have wires that will burn out. Newer ones are a sealed block that can melt. What will happen is you only have high speed when it starts to fail. Then it will quit altogether. The solid state one I replaced was on a Jeep but it would sometimes work if you wig the wires. When I got it out, it was visibly melted.
Thanks for the replies...Yeah, it didn't act like most failed resistors, like high only as you mentioned, that's why I didn't jump right to that conclusion. It's work intermittently, sometimes I could get it to work by whipping the switch back and forth...other times it'd just pop on while driving down the road whether speed 2, 3, 4 whereever I I happened to leave the swtich when I gave up...but always left it in the on state. I know it's not impossible to have different symptoms, I just wanted more ideas before I wiggle myself under the dash.
